Graupner Speed 700 Turbo Cs
hey, Wheres the best place to get the Graupner Speed 700 Turbo C motors? There used as drive motors in Savage Evo and at uk champs one locked up for some unknown reason and the other one bust an endcap off. Untill i decide what im doing with the drive system im going to keep using the speed 700s.
tom, their s a few places to get them cornwall models is one that springs to mind, they all charge £20 each pretty much, i think they are too close to the disk motors, and when impacting the disk motors are hitting the drive motors. this never happened when it had 2 teeth, but did it too me once on single tooth, thought it was a one off tbh as it didnt do it again, but when you said it happened to you it makes me wonder. its a basic brive system on it (built by mario) so its the only thing i think can cause it. if you remove one of the motors has it got a small inprint/dent on the side of the casing where the motors sit closest together (disk and drive?)
easy to sort though if you remove the bottom plate, cut and reweld the bottom support further away it would cure it.
(Message edited by ady on March 16, 2009)
Ok,Cheers.
Ill replace motors and sort out my electrical probs with the weapon system and thats all imma do to it for now. It worked well so untill it gets caught by another spinner and takes alot of damage ill keep it as it is.
