am looking for 100mm wheels to fit drill motors with left hand threads have tryed james, got a price, but can not get hold of him any more, any help or part numbers will help please
Hi - not too sure why you cant get hold of james at the moment. Either James or I will contact you tommorrow.
Regards
left hand threads?!
ok thanks grant have been trying to get in contact with james for about 2 weeks now.yes extended left hand threads to fit to drill motors many thanks await your reply
What drill motors have you got Paul, most have 3/8 UNF Right hand threads.
no i have two bosch drill motors model gsr14.4ve2 which have left hand threads ie turn left does up turn right undoes so i think it is a left hand thread.does anyone know how to remove tourque selecter from drill to save weight as do not want to break gearbox thanks
With a bit of luck itll be similar to this.
http://www.wa4dsy.net/robot/drillmaster/index.htmlhttp://www.wa4dsy.net/robot/drillmaster/index.html
Remove chuck ..http://www.jacobschuck.com/images/tech-support/threaded-spindle-chuck-removal.jpghttp://www.jacobschuck.com/images/te...ck-removal.jpg
CHUCK removed http://www.wa4dsy.net/robot/drillmaster/img_3277.jpghttp://www.wa4dsy.net/robot/drillmaster/img_3277.jpg
Note that ALL drill chucks that I have removed have been Right Hand...the screw inside the chuck is however L.H.
(Message edited by woody on February 12, 2009)
