Chargers?
Hi. What battery chargers do most of you guys use?
I will be wanting to charge two 7.2V 4300mAh NiHM batteries For one robot and one 12v 3700mAh NiMH battery for another robot. What charger would best suit me? and if it needs a power suply what supply would i need? also if you have one of the chargers that you think would be best for me and have charged these size batteries on them before could you give me a rough idea on there charging times.
Thanks!
Chargers?
Hi Tom
I us the Pro-Peak Sigma AC/DC Charger to 5A controller from technobots (however i have seen them for around £75 on other sites)
it can charge loads of different types of batteries including Nimh all the info is on the site, you just plug into the wall and go however you will need to buy some extra wires for charging
thats what i use and my Nimh are charged probably full charge in 1 hr
hope this helps
Chargers?
Whats the supernova like? any better or worse?
Chargers?
SuperNova works well, I think its just the older version with the advantage that you can pick them up for £20 of Ebay.
Dont forget you need a power supply for it though.
Andy
Chargers?
Any others you reccomend? I just need a charger or 2 now. like i said before i just have to charge two 7.2V 4300mAh NiHM batteries For one robot and one 12v 3700mAh NiMH battery for another robot. so maybe 2 chargers would be best. Anyone have owt?
Chargers?
Technobots has some nice chargers, and most good modelshops (either online or local) will have good Nicad/NiMh chargers as well.
