Hi all im after a piece of ali 35cm by 35cm by 2cm
Im after a small piece of Aluminium 20-25mm thick 50mm wide 70-80mm long can anyone help?
might be able to help with the both, might have to wait till after the weekend is that ok?
Craig, I should have something that small at home. Tony would have to see if I could obtain some from work. Will let you both know later. BTW it would be Alumec 89 (ie the good stuff)
Tonys request was made back in June, its possible he may not need it anymore
I could be wrong though :lame:
Yep still need it
Yep, I was wrong :crazy:
Got any events lined up Tony? Havent seen the Team Dragon bots out on the circuit for a wee while now
No no events lined up spent all spare cash on heavy then event was cannceled oh well.
will be at nottingham with me new toy. its not a bot new camera films in HD and High speed vid but not at same time plus stills at up to 40 fps. HS vid up to 1000fps. hopefully get some good vids.
