Okay here it goes
I am having major problems with virus related stuff on my pc, my hard drive is being eaten alive, i have lost 40gb of space due to it. So the chances are i am going to have to get a new hard drive and reformat my computer. So I am hoping to find away to save my stats and everything important but there is a chance I could lose everything. Therefore can everyone help me by locating my stats and posting them in here just in case. Thank you
Okay here it goes
Martyn, first off, I will post Wedginators new stats in here, since I wish to replace the nator 5.0 with the new 6.0.
Wedginator 6.0
Shape: Wedge with scoop at the back.
Colour: Green crocodilian texture.
Picture: http://www.geocities.com/kodybluz/Wedginator6.pnghttp://www.geocities.com/kodybluz/Wedginator6.png
Weight: 100kg
Speed: 24mph
Armour: 6mm hardox 750 all around the main body except the underside, which is 6mm titanium.
Chassis: 3mm hardox 400 box chassis
Drive: 2 x LEM130 at 36v.
Power: 6 NiCad Battlepacks at 36v
Motivation: 6WD. 6 titanium hubs, with vulkalon rubber for traction.
Ground Clearance: 0mm at front and rear, and 4mm at the sides. There is a hardox plate at the front with the name of the bot there, to aid in getting under skirts.
Diemsnions in CM (LxWxH): 95 x 73 x 35
Weaponry: This is where it gets interesting. Wedginator has an all-around flipper this time around, powered by a single 2.5kg CO2 bottle. How does it work? Well instead of the panel coming up to flip, the entire exterior armour is tilted. As the armour is a little heavy, it will probably only be able to flip about 300kg, and toss 175kg, at both ends. It tilts from the back, so at the front it acts like a front-hinged flipper and at the back the scoop acts like a rear-hinged flipper, so it can fend off attacks at both ends. The armour is attached to the chassis at the front to avoid the armour coming off easily.
Srimech: Flipper
Strengths: Unique design. 6WD, extreme pushing power, speed, and acceleration. Hard to get under. Flipper still good despite slight lack of power.
Weaknesses: No damaging weaponry.
Second, you need to get a better computer by the sounds of it. :wink:
Okay here it goes
lol I said mine not yours :p
Okay here it goes
XP
Need to read better. Or get contact lens. XP
Okay Ill help you find them.
Okay here it goes
Mousey 4
SHAPE- Shaped like a mouse with a sort of like front wedge, formed by what would be the mouse€™s face/nose
COLOR- blue, well the fur is, the armour is silver.
WEIGHT- 100kg
SPEED- 13mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 0mm at the front 6mm for the rest
ARMOUR- 5mm grade 5 titanium over that is 3mm fur, which extends over the back to form a tail
WHEELS- 4 inner wheels, like those on storm 2
POWER- s28-400 on 24volts
WEAPONS- flipper on the wedge which self rights the robot
NOTES- covered in blue fur and has two fire storm style flippers to get it off the wall if flipped on wall
STRENGTHS- good armour under fur, fur can jam discs
WEAKNESSES- Limited CO2, it€™s a mouse
Disco 5
Shape: Low Wedge with small rear wedge
Motivation: it now uses four storm 2 style Vulcalon wheels
Speed: 12.5 Mph
Weight: 100kg
Height: 300mm to top of body, 600mm to the top of the disc
Length: 1300mm
Width: 600mm
Weapon: 500mm Vert. flywheel @ 3000rpm. Has a 4.00 second spin up time due to the C40-500 Magmotor on 36v with a 2:1 twin tension cog belt reduction. The flywheel produces 31.5Kj€™s at maximum RPM but is lethal at around 1 second. The second weapon is also the srimech, this weapon is a low pressure pneumatic flipper running on 10Bar (145psi) running into a single 80mm bore ram. This produces 509kg at the ram and is then transferred into the flipper with a leverage point ratio of 1:1. This is a forward facing flipper like FireStorm and will have no problem toppling the heaviest of robots.
Chassis: 4mm Grade 5 Titanium monocoque with extra 5mm Titanium ribs to give it more rigidity.
Drive: 2 x S28-400 Magmotors @ 36v with a 10:1 Mod 2 spur gear reduction
Batteries: 90 x 3000mAh NiCD cells producing 36v @ 9amp
Color- the robot and skirts and flipper are blue and the disc is yellow
Clearance- it has 0mm at the front due to the wedge it has 0mm at the sides due to skirts its 6mm with out it also has a 0mm at the rear due to the small wedge which is there to replace the problem of the skirt being flipped into the disc. The skirts are NOT hinged and held down by torsion-springs so they shouldn€™t spring up and the rear one shouldn€™t go up into the disc
Notes- The flywheel is at the back off the robot it goes over the back of the wedge so if I can get a robot up the wedge far enough it will be hit by the disc. The skirts stop the robot landing on its side.
The Deer (was Crusher Chaos)
SHAPE- Invertible box
COLOR- the robot and claws are a dark green color
WEIGHT- 100kg
DIMENSIONS- 1m x 80cm x 25cm (l,w,h)
SPEED- 15mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- It has 6mm at the front due to the claws and has 0mm at the sides and rear due to the skirts, without skirts 6mm. The skirts also work both ways up.
ARMOUR- 3.6mm hardox
MOVEMENT- 4 inner wheels that make the robot invertible
POWER- 2 x S28 Magmotors on 24v.
WEAPONS- it has a front pair of horizontal hydraulic crushing claws set up like deers antlers (shaped like those you find in extreme destruction.) The claws have 3.5 tones of crushing force on the front tips of the claws at the middle is 6tones and right at the back it has 8 tones of crush. The claws are powered by hydraulics through a 120mm bore rams at 3000psi
NOTES- invertible, wide base means the deer wont topple while crushing
STRENGTHS- Very powerful weapon
WEAKNESSES- it could be turned into venison
Star 69
SHAPE- It€™s a shaped like a five point star but the points are mounted round a inner circle so the points of the star spin round
COLOR- yellow
WEIGHT- 100kg
SPEED- 19mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- about 9mm but is lower under the bottom teeth where it is about 3-4mm
ARMOUR- it has 4mm grade 5 titanium
MOVEMENT- it uses 6 inner storm 2 wheels
DRIVE- it uses 2 x lem 130€™s
BATTERIES- 4 x 30 cell 36volt 3ah Sanyo NiCad packs
WEAPONS- as I said it has an outer spinning ring so is a fbs the ring is powered by a C40-500 Magmotor, the points on the star each have sharpened teeth on them and it spins in a clockwise direction, each point has 3 teeth on it, one on the bottom for tearing at skirts in wheels, one in the middle for body work and that, and one at the top for aerials and tall robots.
SRIMECH- Invertible, points and blades stop it from sticking on side
NOTES- according to frank the name is rude, first star shaped robot
STRENGTHS- Powerful weapon and drive
WEAKNESSES- people not wanting to call it back?
Panicking (previously Panic 3 GTI)
SHAPE- Low invertible box
COLOUR- Yellow except for the lifting forks which are black
WEIGHT- 98kg
DIMENSIONS- 65cm x 60cm x 15cm (Length x Width x Height)
SPEED- 23mph
TURNING CIRCLE- 0 mm
GROUND CLEARANCE- 0 mm at front due to forks, 0 mm at sides and rear due to skirts 7 mm with out, the skirts are hinged so flop over when the robot is flipped
ARMOUR- 12mm polycarbonate
MOVEMENT- panic now uses 6 Vulcalon wheels to give extra pushing power
POWER- 2 x LEM130€™s on 36 volts
WEAPONS- on the front the robot has a pair of invertible lifting forks, the forks are sort of like those on panic attack, the forks are powered by 2 linear actuators
STRENGTHS- Low ground clearance
WEAKNESSES- previously lost to spinners!
Rammy Mk 3
SHAPE- Invertible box with front hinged wedge
COLOUR- Blue
WEIGHT- 94kg
SPEED- 20mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 0mm at the front due to wedge this is both ways, 0mm at sides and rear due to skirts 8mm without, the skirts can be taken off if they aren€™t needed for the fight
ARMOUR- 4mm Hardox
MOVEMENT- it has 6 inner vulcalon wheels
POWER- it uses 2 x lem 130€™s
WEAPONS- The front wedge can lift up and down powered by a linear actuator, this is only used if the opponent is winning to help get aggression points from the judges. The wedge is hinged so works both ways up however the lifter isn€™t as affective when the robot is flipped though it still works
SRIMECH- Invertible
NOTES- Rammy finally comes to the fra after entering frw 8 and some arc tourneys
STRENGTHS- Compact in size, great pushing power
WEAKNESSES- Comparatively Light
All from The Crash & Burn Tournament 2 :)
Okay here it goes
Here are some more older ones...
Disco-Tech 2
COLOR- silver
WEIGHT- 100kg
SPEED- 20mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 6mm under the discs has 0mm at sides due to skirts that will work when flipped
WHEELS- it has 6 inner vulcalon wheels
POWER- Drive: 2 x S28-400 Magmotors @ 36v with a 10:1 Mod 2 spur gear reduction connected to the 6 wheels.
Batteries: 120 x 3000mAh NiCD cells producing 36v @ 9amp
WEAPONS- It has 2 spinning each spinning at 3000rpm. Has a 4.00 second spin up time due to the C40-500 Magmotor on 36v with a 2:1 twin tension cog belt reduction. The flywheels produce 31.5Kj€™s at maximum RPM but is lethal at around 1 second. It has one weapon on the front and one on the back
SRIMECH- Invertible
NOTES- can spin on the spot
STRENGTHS- fast, powerful weapons, good pushing power
WEAKNESSES- easy to flip if discs aren€™t spinning
Happy Birthday Party Pooper
SHAPE- invertible disc (like gyrobot)
COLOUR- Blue
WEIGHT- 150kg
DIMENSIONS- 100cm diameter X 20cm height
SPEED- 10mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- its about 10mm but 3mm under the blades
ARMOUR- 6mm titanium body
MOVEMENT- it runs on 8 inner anarchy style legs.
POWER- 2 x S28-400€™s Magmotors on 24v.
WEAPONS- it has a powerful spinning shell spinning at around 1500rpm weighting around 65kg powered by 2 X LEM-130s running at 48v, it has 12 typhoon2 style teeth around the out side 4 around the bottom 4 around the middle and 4 at the top
NOTES- all components have been shock proofed with rubber around them.
STRENGTHS- very destructive weapon
WEAKNESSES- easy to push if weapon not spinning
Catus Catus 8.1
SHAPE- It€™s shaped like a cat about to pounce
COLOUR- black and white
WEIGHT- 150kg (it€™s a shuffle bot)
DIMENSIONS- 90cm X 78cm X 35cm
SPEED- 18mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 0mm at the front due to jaws, 0mm at rear due to tail and it now has 0mm side ground clearance due to new side skirts
ARMOUR- it has 3mm hardox
MOVEMENT- moves on 8 inner camshafts
POWER - 2 S28-400€™s on 24volts
WEAPONS- It has a front pair of growler style crushers shaped like a cats head powered by a 80mm bore ram with 3000psi hydraulics, the rear weapon is a flipping tail powered by 80mm Bore ram on 1000psi pneumatics.
NOTES- has curved sides to stop landing on side
STRENGTHS- great weapons, self rights with ease
WEAKNESSES- Limited co2
Call out Hook
SHAPE- low box wedge (like storm 2 but not invertible)
COLOUR- white
WEIGHT- 100kg
SPEED- 23mph
TURNING CIRCLE- 0mm
GROUND CLEARANCE- 0mm at front wedge, 0mm at sides due to skirts 6mm with out 6mm at rear, varies under weapons
ARMOUR- 4mm hardox
WHEELS- 6 inner Vulcalon wheels
WEAPONS- Weapon- On the top of the machine, there is a 360-degree rotating turret, on which can be mounted 2 weapons. The first one is a large CO2 powered lifting arm, running off a 80mm ram at a pressure of 750psi. It has a hook shaped arm on the end, which is designed to pull up and puncture wheels, whilst lifting at the same time, and also to enable it to penetrate skirts. This ought to lift around 268kg around 40cm into the air at maximum. The other weapon that can be chosen is a double-headed horizontal axe shaped like that of Terrorhurtz, which will spin around on the turret, enabling him to do both damage by spinning and hammering. This should be enough to cut thin titanium, and dent the thicker sheets. The turret is powered by a LEM 130 geared at 4:3 giving good speed it spins at around 2000rpm and reaches it in around 3-4seconds
SRIMECH- the lifting arm which can self right from any position due to the turret
STRENGTHS- good weapons, good pushing power
WEAKNESSES- if the arm is spinning round slowly it may topple
Battle record- Heat finalist in Kodys war 2
Any more you want? :)
