Spectrum system question
hi all
i now have a spectrum, and had put it in psycho fling but as only block of wood is going to nottingham i have decided to put it in there for that event. there isnt anything i need to do to it before swapping it over? its proabaly a bit of a silly question but block of wood wasnt working, i havent tried to fix it yet but want to make sure im doing everything correctly
thanks alex
with spektrums in different robots you would probly need to bind again has the failsafes might be in a different position???
ill read up on how to do that, matt did it for me in psycho fling
also looking for aanother reciever as i believe you can run more thanm one reciver off the same transmiiter is this correct? Ive been looking around on the net and have found one for £42, does this sound normal?
thanks alex
to bind it put the bind plug in the battery terminal the first 1 and then push down on the button on the back of the spektrum and turn it on the reciver should flash orange when it stops blinking and just shows the orange light take the bind plug out and your done
Yes, you can run more than one reciever off of one transmitter, I am currently running 3 off of one.
Will
Important note:
When you bind the receiver to the transmitter, this sets the failsafe positions. E.g. When you bind, the receiver remembers the stick positions at that point in time. This is the only way you can set the failsafe.
As matt says, the bind procedure is as follows:
1. Plug bind plug into receiver BAT connector.
2. Turn receiver on (best to do this with only a receiver battery connected).
3. Press and hold bind button on rear of transmitter.
4. Turn transmitter on and keep holding button until receiver light goes solid.
5. Remove bind plug on receiver.
6. Turn transmitter of and double check failsafes work correctly.
do i just put the battery pack for the reciever in another plug, as the bat one will be taken with the bind plug?
thanks alex
thanks, just realised the rx battery wasnt attached to the switch, solved the problem straight away (i bet you are all thinking idiot)
thanks anyway alex
