Hi everyone.
I have a problem wiring my speedos to my receiver.Can someone tell me how to do it?
Thanks.
Dan.
Hi everyone.
Thanks.
Dan.
???? What speedos?
Normaly you have 1 3wire cable from the speedo, with a little black plug on it. This should go into the reciever. The choise of plugin you make will decide what stick or button will control it.
My speedos are sonik marine 25amp.I have tried what you said.
Can you check the reciever works with a servo and battery?
What way round did you fit the plug into the receiver. Black wire usually goes to the outside edge of the RX.
Dan your not using more than 12 volts supply are you?
Can you try with just one Mtronik ....if you havent already.
I cant remember if your speedos have them or not, but are there 2 very thin black wires comming out to a switch? if so, turn one switch on and the switch on the other speedo off. That will supply power to your receiver if your not using a seperate battery pack.
Also, just double check that you have plugged them in the correct way around - it can switch depending on your receiever.
(ill send the e-meil with rack info etc later)
Dan,
Is this all sorted now or would you like some advice?
Thanks eveybody.All fine now.
