Electronize electronic switcher
hi
rewiring my lifter motor micro switches and the electronic switcher, bit stuck becuase, i know that the Nc goes to the power but does one go to the postive of the power distributor and the other to the negative? if yes which way around?
i have put a pic on my site, robot improvements
http://www.psychoflingteam.co.ukwww.psychoflingteam.co.uk
alex
put a better explanation next to the picture, might help
i have found some instructions that i think might help on the technobots site, but it isnt working the download i mean, could someone see if it works for them and email it to me? i dont know if this is the problem but technobots have discontinued the zeobot range
anyway if anyone has any luck please post
cheers alex
its ok now i have got it to work! (the download)
i have got the lifter working, well working as in the mechanism moves up and down at quite a fast speed, although i seem to be getting a bit of interference which make the lifter motor move in bits, any ideas? also when the lifter is working the drive mototrs seem to twitch?
any thoughts welcome, i wont be able to respond for over a week as im off on my hols
thanks alex
only one way to sort it out in an instant - Buy a DX6 :proud:
It will more than likely be that the motor used for the lifter is giving off alot of noise. Capacitors on the back of the motor usually do the trick.
