Speedo connections to motors
hi all
just checking i have got something clear, is it ok to solder blue/yellow wires from electronize to two motors then solder another bit of wire from say the positive to the positive on the other motor, then do this for negative and the other side, would this achieve 4 wd?
if my explaining is dodgey as some people find it is i have a diagram on robot improvements on my site
thanks alex
http://www.psychoflingteam.co.ukwww.psychoflingteam.co.uk
As a minimum you will need two speed controllers... otherwise your robot will either only go forward and backwards or only go in a circle.
i do have 2 spedos, sorry for not including that
Your diagram is fine and should give you 4WD.
hows it coming along? im going with 4wd using 4 motors. got any progress pics?
well its psycho ram im on about, i was just clearing the wiring up. its only newly built theres some more info on the tech page of my site, http://www.psychoflingteam.co.ukwww.psychoflingteam.co.uk
what motors you using? the ones in mine are drills
alex
i might go with 9.6v drill motors.
