Hi guys, has anyone got any links to a build diary with photos, just to give me guidence, or even photos of feathers with the lid off, ive gone through sum threads but struggling a bit
http://www.kickinbot.com/http://www.kickinbot.com/ found this very useful when building my FW:)
Pic of simple pushbot on my profile.
that helps alot, cheers. where im at, at the moment tomorrow im buying some cheap challenge 9.6v cordless drive from argos £9.99 each x 2. im planning on building a 2 wheel flipper bot. i took apart an old cordless drill lying in the garage to see whats inside. i presume when i take one of these challenger drills apart i will have the same. which was the motor,the torgue adjuster and the chuck on the end. it all came out in one piece.will i be mounting the whole thing or do you remove certain bits? im sorry if i go over old ground guys. also im planning on using nicad r/c batterys, what sort of voltage should i use on these motors? and would these things be powerful enough as they look a bit small (being used to bosch 750w on my heavy doesnt help!)im hoping to build a diary of every stage as feathers are completely new to me and to help anyone for the future, i just want to make sure im building something that will perform ok.
Adrian.
Im working abroad next week, but after that (20th onward would be best for me) you are more than welcome to pop up to my workshops in Wrexham and have a good look inside a few different featherweights. I have a lot of different solutions and motor/controller combinations for you to have a look at, and try out to see how they perform.
james that would be good, i know wrexham well (used to go to demon tweeks a few years ago) let us know when your about would definately up for that, ill chuck the heavy in the back of the car to cast your eyes over.
thats a date then :) lol
Ill see if my team mates will bring their machines up too, and you can see the full size of the xbotz army. I think youll be surprised :)
looking forward to meeting ED-209
http://www.teamturbine.comwww.teamturbine.com
Click on DB5 it wil give you 5 years of diaries about building feathers.
cheers ed, should keep me busy for a bit!
Here is another 127 pages of featherweight building experience from down-under: http://www.robowars.org/forum/viewtopic.php?t=74&postdays=0&postorder=asc&start= 0http://www.robowars.org/forum/viewto...der=asc&start= 0
Handy if you want to build a spinner, use parts from Whyachi, weld aluminuim, use titanium and endless other topics.
