My first written fight.....
Mute V Panic Attack
3...2...1...Activate!
Both robots start slowly, testing each others abilities. It looks like Panic Attack is on the attack. PA comes on the side of Mute and starting pushing Mute around. Then PA uses the forks to flip Mute over. Mute responds by doing a spectacular self-right. To up the stakes, Mute hits the pit open button. Mute charges staight for Panic Attack, and pushes PA into CPZs end where Shunt is waiting. Mute flips PA over. PA slowly self-rights but before it self-rights fully, Shunt puts its axe into the bottom of PAs skin. PA gets away and heads for the middle of the arena. Mute charges at PA, and PA goes right over the top of Mute (deja vu anyone?), but after that PA gets the forks on the side of Mute and pushes Mute into the pit. But wait, Mute self-rights from the pit, incredibily. The time is down to the last minute, and both robots are at their finest. Mute gets alittle under PAs side and they go in a circle. PAs skirt breaks away from the body. Mute backs away and gets under PAs back side. Adam fires the flipper and PA goes straight into the arena wall. Mute quickly pushes PA into Sir Killalot CPZs end. PA self-rights and both robots go into the middle of the arena, PA pushes Mute around one last time.
CEASE!
Well, what a close fight. It will have to go to the judges.
Out of 5
Mute
S:4
C:4
D:2
A:4
Panic Attack
S:3
C:4
D:1
A:4
Mute: 14
Panic Attack: 12
And there you have it, Mute wins!
Actually, thats not bad. Maybe a tad unsure about the un-pitting, but there you go.
You could have a future.
*puts X-Factor music on
Im gonna say... Yes. A good fight there, Kevin. :)
(Message edited by team_britespark on September 10, 2005)
Adam said that Mute COULD self-right from the pit.
Well at least I was pretty realistic unlike some other writers.
What did I do? :S
Oh, nice fight BTW.
Pretty good for a first effort, just one or two pointers.
1) Adam may have said that Mute could self right from the pit, but the way Mute self rights it would probably hit the wall on its way up and fall back into the hole.
2) Mightve been a touch short for a fight going to the judges, but that may just be me.
But all things considered, good work:)
