Anyone know if they have a reverse gear?
No, they're meant for planes which don't require a reverse gear. Aren't you TZ85s holding up?
Yep, They are still good, just building a beetle too.
When I bought the Turnigys the ad said cars, boats planes. Oh well, will find something else. Needs to be small enough to fit in a 37mm tube with a battery and all the gubbins.
For a beetle, Botbitz 10A ESCs are pretty decent. Not sure if they're in stock though.
VEX 29s are also pretty good and usually available
Intrigued by the vex29. 3 amps seems a bit low - are they fat American Amps? Is it just a matter of popping the connectors off or do they need modding?
This should have all the info you need:
https://thevariableconstant.blogspot...roller-29.html
I have a Turnigy 30A on a weapon motor one-way for that is fine. What about a Sabertooth ? I have a 12A RC and impression is good. Pretty sure the 12A is sustained and much higher burst. Duel channels and built in mixing.
