FeatherTwo Featherweight Controllers
I've reacently re-released the FeatherTwo controllers. They are available in two versions.
Dual channel mode comes with mixing and does both sides of the drive. They are suitable for 2 or 4 wheel drive with argos drills, Gimsons, etc.
Single channel mode is aimed for higher current stuff; they will run pretty much any brushed motor you can fit in a feather, and will even run some of the lighter duty heavyweight drive systems. They are a drop in replacement for TZ85s.
Both versions work up to 6s (24v). They are available on Alex's store: https://nutsandbots.co.uk/product-category/components/
They have been well tested in combat after the original production run last year. The biggest test came running the huge motors in Steve for insomnia, and they worked great. https://youtu.be/6GK6fRqZ59s
