Could someone run their eye over my maths- I think there's an error
I'm was getting some pretty big numbers out- but I realised I was using the diameter not the radius. I just wanted to check I hadn't missed something else daft!
Calculating force at the tip of a flipper:
Ram is 3.94 inches diameter
=12.19 InchSquare
Gas pressure 1000psi
1000*12.19 = 12 190 pounds of force
Which is 5529kg
Say I lose half through inefficiencies:
2500kg at the ram
If the ram is 10cm from the fulcrum and the tip of the flipper is 1m away there is a 10:1 reduction so
2500/10= 250kg @ tip
Sounds reasonable to me. Can anyone confirm? :)
