Hi all,
Does anybody have a reliable link to the SimonK reversing firmware? I'm looking to install it on some opto Afro 30a ESCs.
Cheers
Dan
Hi all,
Cheers
Dan
The SimonK code for the TZ-85s is available here: https://github.com/c---/simonk_tgy3d...2949bef47ad001
But I don't know if that's suitable for Afro 30s, I just got the link from Rory R9000's build thread. The bs.hex file was the one he used but there are afro.hex files on there, no idea if they're what you need :P
Here is the readme for all the files on that github. It doesn't give any info about Afro30As specifically, but I'd put good money on just trying afro.hex. I'm guessing a 30A ESC won't be classed as high-voltage, so give that one a try. I bet they all use the same chipset anyway. If all else fails, you should be able to find the original firmware and re-flash it right? I'd say try it.
Habe you checked out blheli? It should deliver similar performance, but it has a nice GUI (so even I managed flashing afro30s).
Thanks guys. Don't mean to be cheeky but I don't suppose somebody could compile an amended afro_nfet.hex file for me with the RC_PULS_REVERSE = 1 option selected? It's been a long time since I've done any programming!
Cheers
Dan
If I knew how, I'd be happy to xD
Here's the link to the 'afro_nfet.hex' file I've been using for my Afro 12As, should also work for Afro 20As and Afro 30As.
Link
I found it was a bugger to re-flash them via the single wire link as the stock firmware had the silicon chip ID set to an ATMega328 instead of an ATMega8 which is what they actually are. I eventually used the force option on AVRDUDE to just jam the firmware in there with no concerns to warnings. I wouldn't recommend this route, but it did work *shrug*.
#edit# I generated these files using the RapidFlash Google Chrome App.
Thanks guys! I shall give it a go later.
flashed them yesterday and gave both escs a quick successful test. Next step will be to adapt the drill gearboxes and motor shafts so they can be attached. Once done, I'll post some pics.
