as above the condition is nearly new the brushes don't look like they are bedded in! looking for about 75% cost new (that's about £200) or Second Hand HW speed controller WHY
thanks
thanks
This is the motor :proud:
Attachment 5789
AmpFlow motors are designed to give the highest level of performance possible in a brushed DC motor. This is achieved by advanced design and the use of rare-earth magnet materials.
This motor has been used for many years by champion robot builders.
This is a smaller, lighter version of the popular A28-400. Same diameter and powerful magnets, just in a shorter, lighter package! And would you believe a whopping 3 horsepower from a 3.8lb motor?
Specs
Diameter 3.0 in.
Length 4 in.
Peak Horsepower 3.0
Peak Torque 1970 oz-in
Efficiency 82%
RPM at 24V 6000 rpm
Shaft Diameter 1/2 in.
Shaft Length 2 in.
Keyway 1/8 in.
Capacitors Yes
Magnet Type Neodymium
No Load Amps 3.4 Amps
Stall Current 285 Amps
Terminal Resistance .064 Ohms
Kt 5.32 oz-in/Amp
Kv 254 rpm/Volt
Rotor Inertia .02 oz-in-sec^2
Thermal Resistance 3.2 degC/Watt
Weight 3.8 lbs.
Sorry the motor is now sold.
