When I bought my Dx5e transmitter I erroneously bought the left handed version. I wondered if there are any left handers out there who own right handed Dx5e who would be interested in doing a swap?
Cheers :)
Cheers :)
By left-handed, do you mean that the ratchet is on the right-hand stick and the spring on the left? If so, can you not just pop the case open and swap them around?
If it's anything like the futaba sets then yes you can. Just make sure to disconnect the battery before opening up.
When I'm next at home I'll pop it open and have a look. I cant remember if I have already tried this... I'll get back to you!
You can swap them around, and behind the front plate there is a hidden switch to turn mode1 into mode 2 or vice versa (throttle left or right). I've done this already several times.
