Beetle frame + misc parts
Hello people. Can I have some money please?
2x 2100kv 2.6kw inrunners. These ran in my featherweight. Nice little motors, normal turnigy quality as cheapness. One brand new, only taken out of the box like 3 times and one very used, its been through an esc fire. Still runs fine but is ugly, has a shortened shaft also.
http://www.hobbyking.com/hobbyking/s...dProduct=44533
http://i.imgur.com/lqP9iXN.jpg
Offers.
2x 3800kv 365w outrunners. These ran in my beetle spinning a 500g beater. Hella fast and plenty grunty. One brand new never opened, one used but still runs fine. Shaft replaced with a 4mm silversteel one.
http://www.hobbyking.com/hobbyking/s...dProduct=46578
http://i.imgur.com/rAN7lOe.jpg
£8 new one £5 used
3x Plus 30a brushless ESC's. Two in packets never used, one used with heatshrink cut to allow the heatsink to work better.
http://www.hobbyking.com/hobbyking/s...dProduct=29329
http://i.imgur.com/w5nqkVX.jpg
£6 per new, £4 used
1x Hobbyking HK-50a ESC. Unboxed, never run in a robot.
http://www.hobbyking.com/hobbyking/s...dProduct=29352
http://i.imgur.com/ZLEsMJE.jpg
£5
1x 3548 Turnigy outrunner. Free HTD3 timing pulley if you want.
http://www.hobbyking.com/hobbyking/s...ner_Motor.html
http://i.imgur.com/wuor9qb.jpg
Offers
1x 2836 mystery brushless, that's not just a phrase I think that is actually the brand. No idea on KV or power rating so that is a legitimate mystery. Can is a little bent
http://i.imgur.com/hdFyD7X.jpg
Offers
3x 45mm x 12mm fingertech foam wheels. I am more than happy to make hubs for these for an extra cost.
http://i.imgur.com/Z6X5QxO.jpg
Offers
1x Raspberry Pi. Not a clue about this because it's not really my thing. Picked it up from a charity shop but then realised I have no use for it and no desire to use it. NFI if working, board looks intact. Buy at own risk I guess.
http://i.imgur.com/htROeGf.jpg
Offers
2x Newstyle Dewalt gearboxes. One disassembled, one together.
6x Johnson 600 motors. Never run in a robot
2x 30a electronize. Will take serious lowballs on these lol.
Also I'm more than happy to make hubs/pulleys and other bits of basic turning and milling for people. Just shoot me a message.
Offers
Finally I'm going to put my beetleweight up here. Why you ask? Because of the massive gap between designing it and finally trying to finish it, I've come across lots of things that I would now do differently. Nothing really wrong with the robot at all as you can see, I have just fallen out of love with it and want to move on.
Spec
CNC milled 6082 3-part frame. Bulkheads are 5mm and the main body is made from a 30mm plate, but gives 8mm thick armour.
Massive Hardox 450 single tooth disc designed by Mr Ellis Ware. Pulleys and hub also machined by him. You've all see how formidable Newton is. Same disc.
2826 NTM with a pulley built round the can. Same setup as Newton except a lot less fancy. Works about the same.
You would be getting the frame, all pulleys and bearings and the weapon motor but will throw in a weapon ESC if required Can include 1000rpm motors + 10a bb controllers (what it was originally designed around) for extra.
I'd rather keep my current brushless drive setup unless you are totally totally desperate for it. But I've no problem explaining exactly what I did and what parts I used.
http://i.imgur.com/L2XybLh.jpg
http://www.fightingrobots.co.uk/thre...57-red-wedding
Sensible offers :)
This could potentially be a very dangerous robot, blahdiblah so I won't sell it to a total potato etc.
Of course, any questions feel free to ask or message me. Cheers.
