What do people use for fuses on the HW robots?
I'm changing the format of Gabriel again! and looking for fuses as I run LiPo packs I use maxi fuses 100A but they are bulky.
thanks
Craig
thanks
Craig
they are what I am using in Toonimator
Are these what you mean by maxi fuses?
http://www.ebay.co.uk/itm/2-x-100A-M...item25a366b0b3
They're not far off the smallest you'll get.
You might find the midi fuses better in terms of configuration but I think they're faster to blow so you might want to up rate them a bit if it doesn't rake you above the burst current of your pack.
http://www.ebay.co.uk/itm/100A-Midi-...item234eb22dc7
We use forklift fuses for Bullfrog and the other heavy. Up to 300A in a lead sheet the size of a big stamp.
But at decent car audio sellers , you can buy 300A fuses for £5 or so, with suitabler housings for a few quid more.
100 amp fuse wire doubled up in beast cheap
Thanks guys
I am going to try these
http://www.ebay.co.uk/itm/SCREWFIT-L...item53ec1430fc
they have bolt on connectors and a window to check if the fuse has blown and are not too expensive.
