dx6i mixing
evening
at the moment my beetle is running a twin stick set up with 2 throtals tank style i want to get this on to one stick not fused wich one but i have no clue how to work the mixing and the instructions are really not helping can anyone please give me an idiot proof description of how to do it and any advice for making it a bit less twitchy on the controls
Switch your ESC's onto elevator and rudder. Then enter this:
Mix 1:
Elev > Rud
+100% +100%
Trim: Act
Mix 2:
Rud > Elev
+100% +100%
Trim: Act
To get the turning the right way you may need to play with the reverse and +/- in the mix. Just get each wheel working as it should without the mix (respective to their own stick), then put the mix in and only play with the +/-100% to get it right.
That'll put it into the stick that isn't throttle (the fully sprung one). To have steering on the same stick as throttle and forwards/backwards on the other use aileron not rudder.
thanks for that now to play with it once i get the bot behaving in the first place
