What is the recommended wall thickness of a full pressure CO2 buffer tank in aluminium?
Approx outer diameter of 60mm if that helps.
Thanks
Thanks
The wall of a 12oz paintball tank is on avarage 4mm.
Thanks, thought it would be thicker than that.
The smaller the diameter, the thinner the wall can be.
A 2 kg fire-extinguisher can be up to 10mm. The bottom and neck are way thicker tough.
