If one were to attempt to build something similar to this
http://www.buildersdb.com/botpics/4295.jpg
Which servo / gearmotor should one be looking at? lol
In a beetle you might get away with a 1/5th bigscale steering servo like the Rhino Pro HV ( 270 Ncm (27.5 kg) @ 7.4 Volt, speed: 0.08 sec @ 40 degrees) which you can power directly on 2S lipo. That is already 175 gram of your beetle gone though.
I'd rather use a compact gearbox motor
175gr isn't that bad
Ok cool, will look at gear motors.
a servo will work fine if the arm isnt to long ..... if you have a 10kg cm torque servo on a 5cm arm tip to servo pivot the it will be able to lift 2kg at the tip which will lift a beetle, you can get servos that will doe 15kg quite cheap
i think i have a 10-13kg servo in mine
https://www.youtube.com/watch?v=uQua...Fiwb1u7YWOLHLw
