Hi all
In the fra rules it says I need a fuse for a lipo that is below the maximum discharge of the battery.
So, if my battery's nominal discharge is 60amps and the burst discharge is 100 amps, what size fuse should i use
Hi all
I'd suggest a 70a or 80a. Basically, the lowest you can get away with that doesn't blow under regular conditions.
Cheers ellis, 80 amp it is then
