Threaded inserts
I have been using wood screws for my featherweight. I was recently told to use threaded inserts instead. I have looked on eBay but am not too certain what to get. Can anybody give me a link to some suitable to go into 10mm dhow and do I need anything else apart from the threaded inserts?
Sorry for being a pain but is dhow wood or plastic?
i think you would only manage a m3 insert as the hole required for an m4 is about 6mm and they have a thread depth of about 1.5-2mm depending on which 1 you go for
http://www.ebay.co.uk/itm/M3-x-6mm-S...item3f21b515c8
also there are a push in type specifically for plastic but from what ive see they pull out after a bit off abuse
Sorry predictive text for you, I meant hdpe.
I'm probably being a bit stupid, but when I have put the threads in, I assume I don't use screws. What will I use?
Any m3 bolt should fit (or whatever size insert you get). I'm using m6 inserts and counter sunk m6 bolts on my feather.
