Need to buy a couple of recievers, got a few AR500s which ive never had a problem with but seems they arent made anymore.. just wondered what other people with a dx6i used so i no itd definatly work with mine.
Cheers
Cheers
Orange Rx r620. Failsafes on all channels.
The only orange Rx to truly failsafe on all channels is the bigger one:
http://www.hobbyking.com/hobbyking/s..._Failsafe.html
Bit more pricey though.
The 4ch and 6ch ones will, with majority ESCs, failsafe on other channels in most cases. But that's down to the ESC itself not the Rx.
The r620 will failsafe to user preset settings. Trick is to power up the Rx with the bind plug in then remove the plug to reduce the flashing from really fast to medium. You then bind the Tx as usually with everything as you'd like it to failsafe.
Cheers for the help guys, any particular places that are the best?
Hobbyking, preferably the uk warehouse
You can get 6s on Ebay pretty cheap too.
@ Dan, that's a neat trick!
