Possibly might be needing someone who could cut 3mm steel angle iron
Evening!
Planning a beetleweight and no suppliers on eBay can cut 3mm mild steel angle iron as I'd like it. Want I want is to purchase 30mm x 30mm x 3mm right angle steel (which would have been reduced down to roughly 150mm lengths by the supplier) which is easy enough. I'd then want someone to cut the 30mm x 30mm dimensions to something like 25mm x 28mm.
If you can help out, please pm me and we can discuss. Again, it's only in the planning stage at the mo but would be good to get everything in place.
Cheers!
Dan
