Motor & sprocket Help please
Hi all,
Im in need of some help and links if possible, i have currently been kindly donated 2no 18v drill motors. I plan to mount these centrally in my robot and run a chain to a front and rear wheels on both sides making it 4wheel drive using only the 2 motors. To make this a bit more helpful what i have been donated is just the motor no Gear boxes. I have measured the spindle on the motors and i believe them to be a 6mm or 1/4 in old money (correct me if im wrong:) ) Can a Sprocket be mounted direct to the motor and then geared up at the front and rear wheels?? Is there a preferred method for achieving this? My bot will be running on 4inch wheels so i will also be needing sprockets to fit to the wheels then to work out what the best way of mounting them will be. I'm probs getting out of my depths here but i prefere a bit more of a challenge.
Any help and advice would be brilliant
Thanks all
