Re: Welding lenses/filters
If it's a cheap mask then it's unlikely you will find filters. More expensive = replacement filters available.
I have always been a bit of a fickler with things like welding masks....with the attitude that I only have 1 set of eyes and well worth paying a bit more and keeping my eyes safe.
had arc eye before not fun
i have seen some masks uses the small cell battery but i think that they were the older version
If you can get the unit apart you might be able to replace the batteries. Cheap helmet is cheaper than a replacement lens unit. If you like the helmet you might be able to swap the lens out.
Although seeing that unit from Hong Kong id just order that. No problems ordering from abroad, but you do have to wait for most stuff.
Thanks for the replies guys. I'll have a more detailed look tomorrow and work out the best course of action. I like the helmet but there are plenty online with just as funky designs so if it's more hassle than it's worth to change/fix the lens issue I'll just buy another one.
EDIT: Yeah I've ordered from Hong Kong before, but it's just the time issue. The earliest estimated delivery date on that is 5th April and I'd prefer to get it sorted before then incase I need to do some pre-champs welding :)
