What fuse should I use for my fw and where should I wire it in? I'm using one of these: http://www.hobbyking.com/hobbyking/stor ... ouse_.html
its burst current is 150a so you probably want a 100a fuse
I suggest you fit a 100a max, and 75 amps to be safe, if you're not using a disk or a very high power drive.
You can find suitable models in the better car-audio shop.
In theory you could fit a 150 amp fuse, and be inside the rules. I don't recommend that.
