Re: Base and shell question
I use wood screws to attach the sides and top to my shell, if you use enough and in the right places it can give a good rugged construction.
Hannibalito 3 uses a T-shaped frame, and the shell is mounted on with a sturdy, reinforced hinge at the front. at the back it's hold on with 2 M8 bolts. By undoing the 2M8 bolts, the shell pivots like a car-hood.
It's also our most userfriendly machine. Changing CO2 bottle and recharging batteries takes less than 10 minutes.
i used m4 wood inserts on my first plastic bot and it held it together well and it made it easy to take apart
http://www.ebay.co.uk/itm/M4-x-8mm-Unhe ... 303&_uhb=1
Thank you for the replies! A hinged shell is genious!! The inserts and bolts sound awesome too. Do you use a captive nut etc for the bolts to thread into?
Hannibalitos shell is bolted to the steel frame and hinge. The shell itself is bend and welded HDPE.
For the bolts that hold plates on the shell I used ali blocks bolted seperatly to the shell.
