Timing Pulley Alternatives
Looking at ways to transfer drive from my brushless to the blade, Ali Tmiing Pulleys is the obvious option, but I ideally want something with a shorter profile. The Motor alone is 35mm tall, plus a 15mm pulley gives me 50mm, this just seems too big for a BW.
Anyone know of good alternatives and places for pulleys?
Considering the Brass and Ali pulleys from technobots but unsure how they will deal with the power transfer.
http://www.technobotsonline.com/alum.-pulley-25mm.html
http://www.technobotsonline.com/10mm-br ... screw.html
Re: Timing Pulley Alternatives
I got mine from HPC gears and there belts can be as thin as 5mm wide
Conker's Alu timing pullys are from technobots and they survived a full on gouging by inertial XL so they are definitely strong enough, if a little heavy...
Well these take 6mm belts (which I snapped a little easily) but still stand 16mm tall.
http://www.technobotsonline.com/pulleys ... 5x6mm.html
I guess I need a pulley with no boss. Not dealing with HPC again, any other suppliers out there?
The alternative would be to get a low profile brushless. My only reservations would be I've just bought one that isn't, and I struggled to find one around the 300w mark that was low profile.
Could just chop the boss off?
That is a good point. I have a spare pulley, I'll try modifying it.
