Panic Attack self righter and Razer insides
I've turned the web and Google upside down looking for pictures of how both of the above worked. I've had no joy so far and wondered if anyone had some pictures or knowledge of either. I think I have sussed how Razer did it, with a hydraulic ram underneath the arm and then the extras plonked about either side of the chassis. It would just be cool to see pictures of it if poss, and did panick attack use a cable powered self right?
Thanks
Dave
Re: Panic Attack self righter and Razer insides
Panic Attack's shrimec was always powered by a linear actuator in different configurations, that was why it was so slow. Find the episodes with panic attack in a watch them in the pits, thats probably the easiest way to get a glimpse inside.
As for Razer, check the build diary for Venom. Thats was built in conjunction with Ian Lewis if I remember right, so that will be pretty close without actually having Razer in front of you. Venom's beak is powered by a custom lin-ac which also powers the shrimec.
Hope that helps :)
Actually I'd be quite interested to see some detailed pictures of the inside of Razor. There's a Venom build diary?
I could have swarn that there was but if there isn't then I messed up :roll: I got a good look in side when robochallenge came to Elvington in north yorkshire, but no pics I'm afraid
1 Attachment(s)
this is all i have, its the internals of the 1st panic attack.
That's well cool thank you to all :D
