im not selling any but tescos have their 9.6v cordless drills for £6 at the moment
there isn't a discount in the online shop.
if they are£6 that's a great find peter
Its £9.75 on Tescos online and around £7 if you go in store
ok well they were £6 at the tescos near us
£6 at the one in aberdeen near me as well
has anyone used these before and are they on par with the argos drills or are they a better build quality
haven't used them but they are likely to be the same design/even made at the same factory
ok bought a pair from tescos to check out they seem to be a bit better built that the argos 1s but they have plastic gears cant remember if the argos 1s do or not either way will find a use for them in some project might get a couple more
I'm quite impressed with Argos value drills these days. They've got entirely metal gears and the motor shaft has a flat on it, with a pinion gear that has a matching profile, meaning the gear won't come loose and slip around the motor shaft (a problem I've experienced before). Plus the casing is decent.
Not had a look at the Tesco drills - there are none in my local store - but other value makes such as B&Q's range isn't as good as the Argos drills in my opinion.
lol they must have changed them a bit since i last bought some
