Hi Guys I have a question with regards to your CO2 tanks, I am switching over from HPA to Co2, I am using an unregulated System here in Canada/US system pressure will be around 850 - 1000 psi (the whole system is rated for higher than the operating pressure).My question is My 5lb tank will have 5lb of liquid Co2 in it, is it advisable or infact necessary to have an anti siphon tube in the tank ? I know its designed to stop the liquid Co2 from getting into the system, and draw the gas off, but if I'm infact upside down, then the tube would be drawing the liquid, so hence my question, just wondered what you guys are using.
My two bots using Co2 are Celtic Warrior (new build) and Spatan ( formely Bounty Hunter)
Martin
