Re: weapon motor---need help
Best version would probably be a speed controller, but that might be more expensive. I think most people use battleswitches to activate bigger relays, but i'm not exactly sure how much current a lifter motor would draw. If a bigger relay is needed, I will be using something similar to this for my spinner using the battleswitch-relay-motor setup.
http://www.ebay.co.uk/itm/CAR-BIKE-24V- ... 20c02bf7d3
Thanks for the link. Ill have a look at them. Would the rely be able to reverse the current to reverse the current? Would the speed controller perform better / last longer than a relay for the lifter weapon. Ie. Not burn out.
