Featherweight flipper from scratch?
Hi All,
I`m about to start building a featherweight flipper from scratch, I`ve built a few robots before but pneumatics is completely new for me.
I`ve already been advised to go for a paintball tank and I`ve seen some on ebay, I`m also planning on a 50mm bore 75mm stroke cylinder or thereabouts.
What I really need to know is what other bits are the best to go for (as cheap as possible), ie regulator, valves and stuff? what adaptors will I need for the tank and for refilling too?
I will be at Kidderminster too so hopefully I`ll get some info there as well.
I will want to have it built ready for Memorabilia in November.
Thanks
John
Team 13Black
Re: Featherweight flipper from scratch?
Where is this darn Wiki!!!!!!!!!!!!!!!!!!!!
These are all very valid questions, and given the complexity and danger of Pneumatic systems I can understand why people would seek out guidance - a single source of concise information is desperately required!
Plus I must have read every single Pneumatics related post on the forum and I'm just as clueless as before......
EDIT: Sorry John, not very helpful for you......
Let's start from the beginning.
A paintball CO2 tank (do not buy HPA-compressed air tanks) comes in several dimensions. From 3.5oz ( 100 gram) to 20oz (600 gram).
Adaptor and/or refill station. Any online paintball store can sell you those.
Regulator. I believe there will be new Trevor s soon. Cheap (for a regulator) small, light and specific for RW. (use the search function)
Valves. you need at least 3 valves. Main control valve (this does the work for the weaopnactivation) , pressure relieve valve (safety , to vent overpressure) in a LP system it could be you need 2 of'm, and a dump valve (in most cases this is a small ballvalve)
Best bet is to search on Ebay. Because new pneumatics are expensive.
Other solution is to get custom stuff.
Thanks for your replies.
How do I work out the volume of co2 from the bottle size? I don`t want to buy a bottle that will be too big.
thanks again.
Every kilo of CO2 is 512 liter of gas at 1 bar.
