Results 1 to 9 of 9
Thread: 3D Printing Advice
    Bad Wolf's Avatar
    Roboteer
    Status
    Offline
    Name
    Bad Wolf
    Location
    North Wales
    Posts
    94
    Ive prevously used Online printing companies to print out some designs from Thingiverse but ive been messing around with some designs myself and before I go and print them out I was just wondering if these would work out okay?
    Im still unsure to have the lifting arm slightly out of line of the main body or have it flush, so ive done two pics one inline and the other out of line.
    My main worry is having everything flat on the "bed" if that makes sense? The top pannel is floating, can that still be printed or do I need to flip it and get it level with the bed? Also things like the lifting arm, will that be okay to print as it is? Or will that need to be flipped on its side before printing?
    Also, is there anything majorly wrong with the designs that ive missed? Ive never designed anything on CAD before so any tips are most welcome
    Bad Wolf
    Coolspeedbot's Avatar
    Roboteer
    Status
    Offline
    Name
    James Booth
    Robots
    Antweights: Killer-Wolf 2, Bunny-Ears. Featherweight: CSB 2 (in progress)
    Location
    Dover, Kent.
    Posts
    405
    From advice I've been given, the flipper will need to be printed on its side to prevent the layers braking from the forces it would receive. The top panel can sit flat the right way up but will need supports for the over hanging parts. It floating shouldn't be an issue.
    Bad Wolf's Avatar
    Roboteer
    Status
    Offline
    Name
    Bad Wolf
    Location
    North Wales
    Posts
    94
    Thanks Coolspeedbot! When you say supports, what do you mean exactly? How do I go about creating them?
    Bad Wolf
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Pullover V2 (AW), Leopold (BW) & 1/3 of a Feather (Pushover)
    Location
    Gtr Manchester
    Posts
    130
    I know nothing about 3d printing or CAD... so I'll keep quiet about that.
    As for the lifter arm though, this I can do! I think it looks better sitting proud of the rest of the body but having it flush will protect it from spinners, so if you can make it fit I'd go for flush.
    Team Pushover - Definitely worse at this than you are!
    AW - Pullover, Wej
    BW- Leopold
    FW- Pushover (well, half of it...)
    Roboteer
    Status
    Offline
    Name
    James Booth
    Robots
    Location
    Dover, Kent.
    Posts
    405
    Basically put legs under the over hangs using 2mm thick squares or circles. Theres some examples on this page of my antweight build diary: http://robotwars101.org/forum/viewto...2507&start=135
    Bad Wolf's Avatar
    Roboteer
    Status
    Offline
    Name
    Bad Wolf
    Location
    North Wales
    Posts
    94
    Cheers! That’s a big help! I’ll sort them out in the morning and get it printed! So once it comes just snap or trim off the supports? Also I was going to ask what sort of size depth for the actual sides etc? You said 2mm for the supports, I’ve gone for 4 mm for the sides at the moment, is that too thin?
    Bad Wolf
    Roboteer
    Status
    Offline
    Name
    James Booth
    Robots
    Location
    Dover, Kent.
    Posts
    405
    Yeah just cut them off. 4mm is fine for the sides.
  8. #8
    typhoon_driver's Avatar
    Member
    Status
    Offline
    Name
    Gary Cairns
    Robots
    Hornet 2 - retired Boner - retired Smidsy - Sold 540 - Sold PP3D - Active
    Location
    Aberdeenshire
    Posts
    4,482
    If you are looking to have anything printed in something exotic such as onyx drop me a line Gary@plastiprint3d.com
  9. #9
    Bad Wolf's Avatar
    Roboteer
    Status
    Offline
    Name
    Bad Wolf
    Location
    North Wales
    Posts
    94
    Thanks Typhoon_Driver! Ill be in touch soon!
    Bad Wolf
