Page 1 of 2 12 LastLast
Results 1 to 10 of 19
Thread: Team Pushover: Build Log
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Pullover V2 (AW), Leopold (BW) & 1/3 of a Feather (Pushover)
    Location
    Gtr Manchester
    Posts
    131
    So, after almost giving up last year, here we are. I'm going to create just the one build log rather than keep cluttering up the forum.
    I've just finished up a rebuild of the AW Pullover, chall9enging myself to build as neatly as possible. Now, having finished shrink wrapping all the joints, I plug the battery in, insert link/fuse, aaaand, the fuse blew.
    I think I'm already way underspecced on the fuse anyway, but I obviously have a short somewhere... great...
    Specs:
    NanoTwo V3
    Vex29 for grabber
    2s 20c 3500mah (I think) LiPo
    5A fuse
    2 x 1000rpm (alleged) n20's for drive
    1 x 60rpm high torque n20 for grabber
    25mm tough hub wheels
    Main body is recycled high impact plastic, grabber arm is from an offcut (polycarb version as spare) and bottom/rear panel are 1.5mm polycarbonate
    I digress, first pic of the new log!
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Somewhere on the Wirral
    Posts
    977
    That is so neat, much better than mine at the moment, nice work!
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Location
    Gtr Manchester
    Posts
    131
    If it worked I'd be happy... it's a neat paperweight right Now, I need to remove all the heat shrink and go through every connection and double check polarity etc..., probably even need to de-shrink the Vex29 and make sure I haven't moved a couple wires or something...
    So as function over form, everyone's is better than mine
    Team Pushover - Definitely worse at this than you are!
    AW - Pullover, Wej
    BW- Leopold
    FW- Pushover (well, half of it...)
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Location
    Gtr Manchester
    Posts
    131
    Well... I, erm... don't know how to say this... I appear to have got the + and - the wrong way round in my soldering frenzy...
    So I'll swap them back to where they should be and cross everything that I haven't cooked the NanoTwo...
    And don't worry, I've called myself enough names for everyone
    AW - Pullover, Wej
    BW- Leopold
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Posts
    977
    Oops. I've done that before with a FeatherTwo in the past. Not fun I'll say.
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Location
    Gtr Manchester
    Posts
    131
    Well... no magic smoke at least, so when I get chance to swap it all about it should hopefully still work.
    Then all that's left is to take Wej from broken and battered to fully functional experiment... watch this space!
    AW - Pullover, Wej
    BW- Leopold
    Bad Wolf's Avatar
    Roboteer
    Status
    Offline
    Name
    Bad Wolf
    Location
    North Wales
    Posts
    96
    Looking good mate! Fingers crossed it’s okay! I have been trying to design a new Ant on CAD to have it 3D printed but every time I say to myself “it’s finished” I think “ohh nooo I need to do this or that!” So it’s a bit of a nightmare! Haha but hopefully I’ll get something finished soon and printed out! Pull Over deserves a better Duos partner haha! So I’ll get cracking again today!
    Bad Wolf
    McMullet's Avatar
    Roboteer
    Status
    Offline
    Name
    Sam
    Robots
    Ensign Wedgeley Crusher (FW)
    Location
    Nottingham
    Posts
    122
    That is some sweeeet wiring. I can relate to you getting distracted by laying everything out to look nice, I'm pretty sure I nearly did the same because the black wire either gave a nice colour contrast or was the right size to fit in neatly. :P
    Hope the fuse saved the NanoTwo and look forward to watching the rest of the build!
    Retroman's Avatar
    Roboteer
    Status
    Offline
    Name
    Paul H
    Robots
    Location
    Gtr Manchester
    Posts
    131
    Ooh what's the new one Wolf? Excited to see it, and tbf, even though I couldnt grab, we did ok
    Yeah I think what's happened is I've swapped the fuse/link (luse? Flink?) To the opposite side to save a few g of wire, I'm almost certain I flipped it to put the battery connector to the middle again... like a dolt...
    Thanks for all the comments too guys! Keeping it small and neat has been a nightmare, HAVS stage 1 and 50%ish dexterity in 4 fingers over winter makes things 10x more fiddly.
    AW - Pullover, Wej
    BW- Leopold
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Posts
    977
    If there isn't any smoke or any heat when the NanoTwo is on, I'd say you were OK. I've cooked my NanoTwo by having a servo plugged in the wrong way (Ikari) so bleh. With the fuse, I'd guess you'd be OK, fingers crossed.
    @Bad Wolf: looking forwards to seeing your new one!
