Results 1 to 6 of 6
Thread: Brushless motor help
    A few weeks ago i bought an antweight disc from drizzlebots for my first spinner:
    Looking at it and some brushless motors, im guessing that screws run through the 9-16mm channels. However im not sure if this is directly from the motor or instead connected to a shaft mounted hub bought elsewhere?
    If anyone can tell me what brushless motor would fit with this disc and also an esc that is compatible i would really appreciate it.
    Thanks
    James Williams's Avatar
    Roboteer
    Status
    Offline
    Name
    James Williams
    Robots
    Neophyte, Meteorite & Exabyte (FW)
    Location
    Birmingham
    Posts
    73
    Hi Max
    I own the bar that Drizzlebots sell & bought a DYS1806 motor & 12A Afro ESC to go with it. Both weapons have the same 9-16mm channels & I can attach the bar directly to the motor.
    James
    Team Phyte
    Roboteer
    Status
    Offline
    Name
    James Williams
    Robots
    Location
    Birmingham
    Posts
    73
    PS Afro ESC's are currently less than 1/2 price at Hobbyking, if you're interested in getting one. https://hobbyking.com/en_us/afro-12a...-firmware.html
    James
    Team Phyte
    Thanks for the quick reply, just purchased both Just wondering, will i be able to use a 7.4v lipo plugged into the esc, doesn't seem to mention max voltage in the description just a bit confused.
    Roboteer
    Status
    Offline
    Name
    James Williams
    Robots
    Location
    Birmingham
    Posts
    73
    Yes you can. They are rated at 2-4s, which refers to the cell count of the lipo battery. Each cell is worth 3.7v, so 2s is 7.4v, 3s is 11.1v, 4s is 14.8v etc.
    James
    Team Phyte
    Ah cheers man i didnt know that, will come in useful.
