Results 1 to 3 of 3
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Michaela
    Robots
    AW: Amai, Ikari, Osu, Ramu / BW: Azriel, Shu! / FW: The Honey Badger / MW: Jibril
    Location
    Somewhere on the Wirral
    Posts
    789
    Hey Everyone,
    New year, new starts and all that. 2018 was a busy old year for me for a whole host of reasons. Finally went into not one but two FRA championships and learned a heck of a lot in terms of mechanical and electrical elements (I can solder properly now! :P) in competing over 4 weight classes. For 2019, going to combine all the build diaries into one thread as so to not clog up the forum any more than needed.
    Links to previous build diaries:
    With that in mind, let's move on. I've been umming and ahhing about changing the line up but since Shu! got obliterated at the 2018 BW Euros, I've needed the time off from intense robot building to reconsider the way forwards for Team Kaizen but first, a run down of the current robots:
    Antweights
    I've not explicitly written any build logs for the Antweights here. I've currently got three, those being Osu, which was made as a technical exercise originally to see if I could build one at all. Turns out I could so ended up making it a proper Ant. Made from a recycled Skittles tub.
    Ikari is my bar spinner which is currently undergoing a rebuild. 1400kv brushless outrunner motor driving the bar, 30:1 N20 motors driving it. My intention is to rebuild it out of 1mm polycarbonate this time around rather than a 3mm PVC base plate and 0.25mm HDPE. Ironically, despite the bar blade flying off, this has been the most successful AW I've built. It's won a heat match and a side event at the BotFest pilot.
    Ramu is a Shakey build 2WD rambot that was formerly under Greg's ownership (http://www.fightingrobots.co.uk/thre...eight-for-sale). I've been wanting to get this back into the competition circuit but I need a DSM2 transmitter for the older NanoTwo receiver in there.
    There is a fourth one I am working on for the upcoming Ant Freeze event if I can get it done in time, Amai (Japanese for sweet) which uses 50:1 motors and I've yet to decide on the weapon for that one. Will be using a Cadbury's Heroes sweet tub as the armour (see a theme? :P)
    Shu!
    Shu! has been dismantled and after examination, needs a whole host of new parts for the drive motors to repair from the damage it took during it's two outings in 2018. I've already got a few panels of 6mm polycarbonate to build a new body with (definitely not PVC again!) but it won't be going to the UWE event in February unless I can find the time to sit down and get the bodywork built.
    The Honey Badger
    If you were at EXR Manchester 2018, I don't think I need to say very much apart from BIG HITS forced the retirement of the 2.x version. For those that were at RL Grantham 2018 or at EXR Guildford 2018, you might have spotted the lesser well known 3.0 variant of The Honey Badger which was a nice idea implemented terribly as it kept on chewing up its motor bolts and just didn't work.
    I know why I built it that way but I ended up hating it and eventually put the 3.0 version out to pasture along with myself from the FW scene for the rest of the year. Since then, I mooted making The Honey Badger a Beetlweight but I've decided to keep it in the FW class and make 4.0 similar in design to the 2.x version. In theory, barring a receiver, I have all the bits to make it out of 10mm Polycarbonate, Nylon 6 HS and HDPE, including motors to come from...
    Kaizen
    Kaizen, for those that don't know, came 6th in the FRA Middleweight championships I think. However, if you were at EXR Chatham 2018 or EXR Cheltenham 2018, you might have noticed that above it all, the axe sucked and at the end of the Saturday at Cheltenham, it wasn't moving properly. Turns out it blown up 2 of its drive motors. I did moot changing them to brushless drive but in the end, I've decided to stick with brushed drive for the time being and change the motors to CIM motors.
    However, this warrants a full rebuild, the parts for which are slowly coming together. It'll end up being slightly shorter than it is now but more solidly built.
    So, 2019 will have a few changes. Since Osu, I've been sticking with Japanese names for the robots, largely because of the team name but for a little while, I've been looking at different names as it can be tricky to find a Japanese description that works as a robot name in English and I've been wanting to try something else.
    In line with this, I've been building a new Beetleweight for the UWE event which is going to be called Azriel, which has been build largely with offcuts of material from the BotFest arena and the original build of the Middleweight. I've not finished it but will probably furnish this one with a spinning bar blade.
    Finally, Kaizen is no longer going to be called Kaizen. In keeping with the angelic theme for my "serious" robots, Kaizen is now going to be Jibril. That robot will be receiving a raft of upgrades, including a new axe (the one on there now is from The Honey Badger 2.x!) and axe motor, re-securing the side armour so it doesn't bend anymore and replacement wheels so hopefully it won't burn itself out turning anymore. As noted, it'll eventually be replaced by a new build but I hope to have Jibril ready for RL Burgess Hill.
    So just to summarise, the current roster looks like this:
    AW: Amai, Ikari, Osu, Ramu,
    BW: Azriel, Shu!
    MW: Jibril
    BW: Azriel, Shu!
    MW: Jibril
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Michaela
    Robots
    Location
    Posts
    789
    Couple of updates.
    Ikari
    Spent the last day or so getting the bodywork done on Ikari 2.0 out of 1mm polycarbonate and now it actually looks rather nifty. Unfortunately, it was sitting at 110g and with the spinner motor, that would mean 15g left over for a bar which feels a bit weedy. Then the motor broke so I've decided to change it for a clamper/crusher type weapon (hopefully allowing self-righting as well but it could go out into a arena tomorrow and at least work.
    Azriel
    This one can't though. The wheel hubs decided to wear out on me during a mobility test and then I weighed it. It was sitting at 1800g which given there is actually very little in the robot itself (just a couple of ESC, battery and some motors), is nuts. I've tried drilling weight saving holes everywhere but ultimately, I think it is just too big and lardy for what it is so I am going to junk this body and start again (how is this 1650g?!) I'll need to order some more polycarbonate for this and although I do have a base plate, can't really start on it until the new wheels arrive so I know how much to remove from the base plate to bring the wheels in.
    I still think I can still have it ready for UWE but, as always, rather depends on time and so forth. We'll see, I am still hopeful.
    BW: Azriel, Shu!
    MW: Jibril
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Michaela
    Robots
    Location
    Posts
    789
    Ikari
    So the robot was moving and a nano servo arrived today for the clamper/crusher weapon. I got that in, a nice little hook made up and it actually looks "the business".
    However... the servo doesn't move. Tried the plug in both directions just to make sure that I wasn't being an idiot and nothing. Plugged into a separate receiver from Azriel and nope, nothing. I tried a different servo I had just to make sure I wasn't being idiotic and then the NanoTwo starts getting warm and the whole robot goes out of control. I think the ESC has overloaded because, once again, I failed to cut the positive wire and, of course, no NanoTwos are around atm. I can get replacement ESCs, even a different receiver but it means yet more soldering and wiring. A shame, this was 115g and I was quite happy with that.
    Azriel
    Following on from the weight issue, I've dismantled the body but left it on the base plate and robbed the wheel hubs from Shu! so at least I can prove it's mobility in a week or so. I'll be making the bodywork for the rest of the week when I get some 6mm polycarbonate cut up for this.
    Jibril
    I gave this some thought last night whilst at a game session. The independent 4WD thing, as useful as it is, isn't working because as soon as one corner is freewheeling, the pressure on the other motor on that side (bearing in mind these motors are used in the FW class) just becomes too much so 2WD next time. Though I have 4x CIM motors, so I am going to do a 2 motors to 1 wheel configuration.
    Box section steel has been ordered so I am hoping it arrives by the end of the week. I'll need to get another set of drive gears for this as well along with 125mm wheels but it could very well be moving by the start of February as I have about 70-80% of all the parts for it laying around.
    BW: Azriel, Shu!
    MW: Jibril
