Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Few questions about Motors, Esc’s, HDPE
  1. #11
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Michael
    Robots
    AW: Osu, Ikari, Ramu / BW: Shu!, ??? (planning) / FW: The Honey Badger / MW: Kaizen
    Location
    Somewhere on the Wirral
    Posts
    755
    about the battery. I cannot see it being an issue if you got a charger Plus a lipo bag/metal box ( you shouldn't need it using a battery like that BUT EO may want it)
    I'd play it safe and assume that the same restrictions for Li-Po batteries apply to Li-Ion batteries as they are not specifically mentioned in the section which details the specific battery chemistries in which "no specific precautions" are noted. Then again, I follow the Li-Po rules for my Li-Fe batteries and they are listed. Best be safe than sorry.
    Team Kaizen
    BW: Shu! (Build Thread)
    FW: The Honey Badger (Build Thread)
    MW: Kaizen (Build Thread)
  2. #12
    Maxamuslead's Avatar
    Roboteer
    Status
    Offline
    Name
    Mark Smith
    Robots
    "Blacksmith" (FW) in a bag in bits "Forge Master" (FW) battle worn "Forge Master II" (FW) in CAD
    Location
    Lincolnshire, Threekingham
    Posts
    421
    Lipo rules apply to Li ion But due to them being in a drill battery I do not know if they still apply
  3. #13
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Michael
    Robots
    Location
    Posts
    755
    Yes, I assumed they would but in the same context, just because they are in a hard shell doesn't mean they wouldn't apply, that shell will probably be plastic and offer no fire resistance.
    Team Kaizen
  4. #14
    Weapon will be a shrapnel style disk of ar500 between 2&3 kg ish.. diameter at 230mm one at 300. Depending on opponent.
  5. #15
    Quote Originally Posted by Maxamuslead View Post
    redbrick 200a. side note what is the weapon?
    Isn’t that quite a big ESC considering it says 100amp on the motor specs?
  6. #16
    Roboteer
    Status
    Offline
    Name
    Mark Smith
    Robots
    Location
    Posts
    421
    Is this your first bot? As spinners are Hella dangerous and Shrapnel is one of the baddest in the fw class
  7. #17
    It will be the first competitive one that I will enter at an event.. I made a 4wd rambot last year and had it for a while but wanted to go the spinner route now there is more full combat events.
  8. #18
    The standard powertool batteries are large and heavy compared to what they are capable of.
