Page 3 of 3 FirstFirst 123
Results 21 to 26 of 26
Thread: Few questions about Motors, Esc’s, HDPE
  1. #21
    Hi Matt,
    Never having an active weapon I cannot suggest from experience, however from a personal prospective, I would go with two separate batteries. Two reasons: 1. you can tune the battery to the system requirements, 2. should one system have a problem the other will remain healthy.
    As for the charger, you can pick up chargers on ebay quite a bit cheaper that will do the job - try looking at an iMax B6 - these can be bought with an integrated charger or separate.
    Hope this helps, regards Cliff
  2. #22
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    AW: Amai, Ikari, Osu, Ramu / BW: Azriel, Shu! / FW: The Honey Badger / MW: Jibril
    Location
    Somewhere on the Wirral
    Posts
    815
    Or Is it worth getting two separate lower capacity ones and running weapon and drive of separate battery to relieve stress on a single battery?
    This is a thing I keep on running into time and time again. The Honey Badger 2.2, Shu! and Kaizen used separate batteries to drive their weapons. However, it does mean more weight and more wiring to deal with but the advantage is that independence which means one system isn't dependant on the battery which drives both. However, in my new Beetleweight and Ikari, they use a single battery for both drive and weapon. Less weight but more risky. Depends on what the design calls for ultimately.
    BW: Azriel, Shu!
    MW: Jibril
  3. #23
    points taken.. :-)
    what about the Yellow zippy lipos then?? They a decent make to use?
  4. #24
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Posts
    815
    Never used them, so can't say. However, the blue Flightmax batteries I have good experiences with. Only had battery failure after genuinely flattening the LifePO4 batteries I use by over-exerting them.
    BW: Azriel, Shu!
    MW: Jibril
  5. #25
    Team RCC is using the Zippy Compacts for a while now. No complaints there. These do the job fine.
  6. #26
    Okay then. Thanks for the info everyone. Looks like I got myself a hobbykong shopping list now then. Haha
