Page 1 of 2 12 LastLast
Results 1 to 10 of 14
Thread: Red Brick ESC Programming
    Max's Avatar
    Member
    Hi,
    Has anyone managed to successfully program a Red Brick ESC? I’ve got the 125A version and am trying to set the number of lipo cells (it seems to be currently set to 7s so keeps cutting out with my 6s pack), but the sequence of beeps doesn’t in any way resemble what the manual says should happen. Google also isn’t providing any help other than showing other people have the same issue as me!
    Any help would be much appreciated
    Ocracoke's Avatar
    Team Kaizen
    I've got a little bit of experience in programming the 100A v2 version. I don't recall if the SimonK code specifies the number of cells in it, I'll check a little later on tonight.
    BW: Shu!, The Honey Badger
    Max's Avatar
    Member
    Thanks that would be great!
    Ocracoke's Avatar
    Team Kaizen
    There is a function in the SimonK assembly which can hard code how many cells it is expecting (CELL_COUNT) and get it to bleep how many cells it is detecting before arming (BLIP_CELL_COUNT) so I'd look at setting those and then flashing your Red Bricks. For what it is worth, my 100A V2s work fine on a 6S LiFe setup with the flashed firmware.
    Max's Avatar
    Member
    Hmm I wasn’t planning on flashing then but have got the AVR programmer from hacking TZ85As so guess I could. Mine is the version 1 I think, guess I need to find a diagram for the programming pins
    Interested to know if there was an update on any progress on this?
    Ocracoke's Avatar
    Team Kaizen
    I've got it working. Not perfectly but it is working :P I'll update more on The Honey Badger build thread later on this evening.
    Ocracoke's Avatar
    Team Kaizen
    Sounds as if the out of box motor timing is out for the motor potentially, what voltage is going to it? Given that there are 7 poles on the old 5060 version apparently (https://hobbyking.com/en_us/ntm-prop...0kv-2665w.html), I'd imagine this motor would be the same or similar so looking at the 200A instructions (https://cdn-global-hk.hobbyking.com/...9X43349X43.pdf), you need to look at the timing modes for it.
    As an aside, I can't say for the 200A version but on the 100A version, I use a USB programming tool (the same sort as the one used on the TZ85A to make them brushed) to flash the ESC with (this specifically: https://hobbyking.com/en_us/usbasp-a...occessors.html).
