Results 1 to 6 of 6
Thread: Suggested Drive Motors
    Hi all, I have been setting out a Beetle weight robot design and stuck on which drive motors to use for each wheel. The design is a typical two wheel driven robot. Any suggestions or experiences will be welcomed.
    Regards
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    AW: Amai, Ikari, Osu, Ramu / BW: Azriel, Shu! / FW: The Honey Badger / MW: Jibril, Kaizen
    Location
    Somewhere on the Wirral
    Posts
    835
    Shu! uses a couple of Como 918D motors (https://www.technobotsonline.com/918...otor-15-1.html) which move it quite happily. However, if I was going to build it again, I might think Pololu 37D motors would be better for the extra grunt (https://www.technobotsonline.com/pol...red-motor.html).
    BW: Azriel, Shu!
    MW: Jibril
    Hey Michael, unfortunately running on 3" wheels that only gives me a theoretical 4mph max speed. Was hoping to achieve at least twice that speed. The tyre configuration should give me the traction so I can ramp up speed fast with minimum slippage. Maybe I am aiming to high, not sure.
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Lucy
    Robots
    Location
    Posts
    835
    On the little wheels I've got, Shu! moves at a relatively steady pace as below (5 minutes, 27 seconds into the video):
    There are some that are much quicker but for my purposes, the Como motors work rather well, if a little underpowered.
    BW: Azriel, Shu!
    MW: Jibril
    Ummmm interesting, maybe I should be waiting till Sunday at the RoboDojo event. Just getting itchy fingers...lol
    Thanks Michael.
    Craaig's Avatar
    Member
    Status
    Offline
    Name
    Craig C
    Robots
    AW- Snappucino. BW- Snappy, Mr Cat's Mouse House. FW- Mr Cat's Mouse Mansion. HW- Two-Headed Death F
    Location
    Bristol
    Posts
    12
    Typical beetleweight drive motors are 1000rpm 25mm gearmotors found all over eBay - https://www.ebay.co.uk/itm/2-x-12V-1...cAAOSwS5NZgCfQ though I recommend shopping around to try and find the best deal. Also, the plastic-backed ones seen there appear to have more power than the metal backed variants.
