Page 10 of 10 FirstFirst ... 8910
Results 91 to 95 of 95
  1. #91
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    46
    Finally managed to get my drills apart to see the motors lol
  2. #92
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    46
    Due to car buying and house renovations this has been on hold but due to the FeatherTwo ESC's popping back into stock I finally have all the parts I need to get started, this is my basic parts layout, motors will be at the top back corners, will draw these in later
    Also got the drill motors out and in the mounts (big thanks to Roboteernat for these, made things so much easier)
    Im planning to use both batteries as ive shown above, or do people recommend just using one? Looking for a wiring diagram to work from and they all seem to show one battery used.
  3. #93
    James Williams's Avatar
    Roboteer
    Status
    Offline
    Name
    James Williams
    Robots
    Neophyte (FW) Meteorite (FW)
    Location
    Birmingham
    Posts
    45
    Are you planning to use the drill batteries? Neophyte runs on only one drill battery but it is rather slow. To be honest most people would recommend running 1 lipo compared to 2 drill batteries, as the lipo would weigh less than both combined & potentially kick out more power depending on your choice (you would need a fuse for that though). If you do run two batteries I recommend wiring them in parallel.
  4. #94
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    46
    My original plan was to use both drill motors but if you think buying a LiPo would be better I will do that, what would be a good one?
  5. #95
    Roboteer
    Status
    Offline
    Name
    James Williams
    Robots
    Location
    Birmingham
    Posts
    45
    Have a look at this as a starting point: https://hobbyking.com/en_us/turnigy-...html?wrh_pdp=1
    It's a 14.8v which is similar to your drill motors & should be OK for the actuator too. You probably could get away with a higher rated (5S) lipo too. Keep in mind that this particular model uses a XT60 connector so you will need to pick up a XT60 connector so you can plug it into the robot. You will also need a proper lipo charger.
    There's a couple of threads on here about starting off with lipo's. I'd strongly recommend reading those first before committing to anything.
