Page 7 of 10 FirstFirst ... 56789 ... LastLast
Results 61 to 70 of 95
  1. #61
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Lucy
    Robots
    AW: Amai, Ikari, Osu, Ramu / BW: Azriel, Shu! / FW: The Honey Badger / MW: Jibril, Kaizen
    Location
    Somewhere on the Wirral
    Posts
    828
    Right, I assume then they mean something like this (http://www.forge-electronics.co.uk/i...l-10a-rc-relay) but without knowing the context (or the wiring diagram), I wouldn't like to commit to anything.
    I've used a single variant of this before on early versions of The Honey Badger 1.0 to power the flail motor but the ones I was using had a horrible habit of sticking open - probably too high a amperage for the switch.
    BW: Azriel, Shu!
    MW: Jibril
  2. #62
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    46
    No worries thanks for the info, will check the wiring diagram later
    PS what site do people use to upload images? Tried to use my old photobukcet account but didnt work
  3. #63
    Maxamuslead's Avatar
    Roboteer
    Status
    Offline
    Name
    Mark Smith
    Robots
    "Blacksmith" (FW) in a bag in bits "Forge Master" (FW) battle worn "Forge Master II" (FW) in CAD
    Location
    Lincolnshire, Threekingham
    Posts
    441
    Quote Originally Posted by AdamST180 View Post
    i use the inbuilt one myself, but imgur is a possibility
  4. #64
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Lucy
    Robots
    Location
    Posts
    828
    You can upload them directly here. Clicking on the add a image button (third from the right when quick replying) and then select the "From Computer" option. Make sure the image isn't too big though (I tend to resize mine to 900x675).
    BW: Azriel, Shu!
    MW: Jibril
  5. #65
    Garfie489's Avatar
    Roboteer
    Status
    Offline
    Name
    Gareth
    Robots
    Dystopia (HW), Enforcer (FW), and Defector (FW)
    Location
    London
    Posts
    310
    A dual RC relay is a device with two outputs that connects to a single channel.
    When the transmitter stick is dead center, neither relay is active.
    Moving up activates one, moving down activates the other.
    My old supply for these is discontinued, so youd have to ask Team Nuts if they can make you one as i dont know any other source ive personally tested.
    My 3 loves - Rugby, Racing, and Robotics.
  6. #66
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    46
    According to this its used in the house robots and the one the Haynes manual says so must be the one i need
  7. #67
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    46
    First few pieces of wooden prototype being cut today
  8. #68
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    46
    https://www.robotshop.com/uk/saberto...or-driver.html
    Are the sabertooth controllers really that bad? As with the FeatherTwo out of stock not sure what other ESC to go for so a bit stuck for now.
  9. #69
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Lucy
    Robots
    Location
    Posts
    828
    Sabretooths are mixed bag. I use one in my Beetleweight and it works fine but that is the 2x5A version. I don't know about the rest. They are also reasonably expensive for what they are.
    Does your transmitter support elevon mixing? If it does, my vote would be to get a pair of single channel controllers and let the transmitter do the mixing that activates both channels with one control.
    BW: Azriel, Shu!
    MW: Jibril
  10. #70
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    46
    Sabretooths are mixed bag. I use one in my Beetleweight and it works fine but that is the 2x5A version. I don't know about the rest. They are also reasonably expensive for what they are and of course.
    I have a Dx6i, not really used it yet but would assume it can do that?
