Page 5 of 10 FirstFirst ... 34567 ... LastLast
Results 41 to 50 of 95
  1. #41
    mrsam's Avatar
    Roboteer
    Status
    Offline
    Name
    Sam Price
    Robots
    Hatchet FW (still running) Hatchet 2FW (in progress) Lynx BW(in progress)
    Posts
    885
    Quote Originally Posted by suvv View Post
    btw if the builder of get shreckt is there and you wish to speak to him he really loves tinned peas they will tottaly get you on his good side
    Damn it Suvv!
    The rest of that advice is sound though, the Haynes robot is good for a project but really you could go a lot better with not much more effort. Build yourself a strong hdpe chassis and you’ll stand up to most of the spinners, aim for around 20mm thick.
    Also don’t buy a Sabretooth, they’re not great for reliability and considering FeatherTwos aren’t much more money it’s a much better investment. You’ll find a tonne of advice all over the forum so it’s worth having a look through.
    Team Riptide
    We do Teamwork we think!?
  2. #42
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    46
    I think as per all the advice might ditch the aluminium, HDPE does sound good, much more modern lol
    I'm gonna keep an eye on when the feather two comes back in stock and with that and a receiver to match my Dx6i I can at least get the motors running and then go from there.
    My aim one day is to build a horizontal spinner but a long way from that lol
  3. #43
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    46
    Been having a think about this and as its been a long time since D&T at school going to make something with MDF before go onto HDPE.
    My plan is to follow the basic layout of the flip bot to create the base and sides out of MDF and get all the electrics going so it drives around and then i have something to build from.
    Would a really cheap jigsaw, like this one; https://www.toolstation.com/shop/p63070 be ok to start with?
  4. #44
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Michael
    Robots
    AW: Osu, Ikari, Ramu / BW: Shu!, ??? (planning) / FW: The Honey Badger / MW: Kaizen
    Location
    Somewhere on the Wirral
    Posts
    722
    Makes sense. With the jigsaw, you get what you pay for - I bought a £18 own brand jigsaw from B&Q last weekend and the blade doesn't quite line up with the guide on the base plate so I've had to mark where it is on the plate so I can cut relatively straight. My jigsaw has the same power output so yeah, should be OK with a wood cutting blade, which you can also use with HDPE as well.
    Team Kaizen
    BW: Shu! (Build Thread)
    FW: The Honey Badger (Build Thread)
    MW: Kaizen (Build Thread)
  5. #45
    Maxamuslead's Avatar
    Roboteer
    Status
    Offline
    Name
    Mark Smith
    Robots
    "Blacksmith" (FW) in a bag in bits "Forge Master" (FW) battle worn "Forge Master II" (FW) in CAD
    Location
    Lincolnshire, Threekingham
    Posts
    410
    Quote Originally Posted by AdamST180 View Post
    MDF is not recommend at all, even for wood, good for prototyping but breaks really easily and HDPE is cheap (i get it from Direct Plastics and i think that is where most people get it from) and is the go to material for first bots
  6. #46
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    46
    Quote Originally Posted by Maxamuslead View Post
    Oh, so would HDPE cut easy with a cheapish jigsaw and a wood blade?
    Worried im rushing ahead to quick so want to keep it simple but also not doing something stupid lol
  7. #47
    Roboteer
    Status
    Offline
    Name
    Mark Smith
    Robots
    Location
    Posts
    410
    HDPE can be cut with Standard wood tools, using a jigsaw run it at a slow setting and don't force it. on thicker stuff (i found with 20mm+) add a bit of water to the mix to keep it from melting and closing the cut back up.
  8. #48
    Roboteer
    Status
    Offline
    Name
    Adam
    Location
    Birmingham
    Posts
    46
    Sounds simple enough, should i start with 20mm thick all over? Or maybe thinner for the base and top?
  9. #49
    Ocracoke's Avatar
    Team Kaizen
    Status
    Offline
    Name
    Michael
    Robots
    Location
    Posts
    722
    Nothing ventured, nothing gained. For a prototype robot (and as a guide for cutting in HDPE), nothing wrong with a bit of MDF or plywood.
    This is up to you. I've done both where the thickness is the same all over with The Honey Badger and Shu! but also where the base is thinner with Kaizen. I would only go with the thinner base/top option if weight was a concern but since it isn't here, I'd go the same thickness all around.
    Team Kaizen
  10. #50
    Roboteer
    Status
    Offline
    Name
    Mark Smith
    Robots
    Location
    Posts
    410
    top 10mm SHOULD be fine (as there is new gen nasty axes coming) as it has been in the past but not sure now. Base Depends on how structural it is, some bots it is just there to stop debris from getting in. Side and back (back could be 12 can't remember) on Blacksmith where 15mm and the only issue i was some bolts pulling through (Binky for you) and drumroll taking a nibble. Look at my new bot Forge Master for the damage report of Blacksmith at Manchester
