Results 1 to 10 of 10
Thread: Lem 200
    I recently was given a couple LEM 200's from my neighbor who was using them in some go karts, I have an interest in using at least one of them in a HW spinner, I'm just lost at what I should use lipo and speed controller wise for it.
    typhoon_driver's Avatar
    Member
    Status
    Offline
    Name
    Gary Cairns
    Robots
    Hornet 2 - retired Boner - retired Smidsy - Sold 540 - Sold PP3D - Active
    Location
    Aberdeenshire
    Posts
    4,445
    Lipo - 12s good quality lipo like optipower
    Speed control - I wouldn't bother unless you can come up with something custom. I would instead recommend a solenoid (speaking from experience here).
    Quote Originally Posted by typhoon_driver View Post
    If you don't mind me asking, did you run just one 12s or did you run some in a series?
    I would run 2 6S packs in series. 6S is easy to recharge with "affordable" chargers.
    Member
    Status
    Offline
    Name
    Gary Cairns
    Robots
    Location
    Aberdeenshire
    Posts
    4,445
    I ran a total of 6 packs on the lem. 4s 4.3Ah wired to give 12s at 8.6Ah. I had to go for smaller packs to be able to travel internationally with them as there are strict limits on pack size when flying. I wouldn't recommend doing it with poorer quality lipo though.
    I think I'll stay away from the LEM then for now, I was wondering though are there any good brush motors for a drum spinner like Magnetar?
  8. #8
    Member
    Status
    Offline
    Name
    Gary Cairns
    Robots
    Location
    Aberdeenshire
    Posts
    4,445
    I wouldn't shy away from them if you can get a hold of them / justify the expense. They are lovely motors.
    Brushed and super high speed typically don't go together all that well. If you want high speed with a small diameter drum then you need to be gearing up your motor in stead of gearing it down.
  9. #9
    The cheapest, most powerfull motors suitable for a disk/drum are series wound motors. Old startermotors from cars for example.
    Biggest disadvantage is that they are inefficient compared to any other motor. That translates in a lot of heat and the need for a big battery.
  10. #10
    J.A.G's Avatar
    Member
    Status
    Offline
    Name
    James Griffiths
    Robots
    Team Griffalo
    Location
    Wiltshire
    Posts
    66
    We run Griffalo on a custom 24v Car Solenoid with Palou Switch..
