Page 4 of 5 FirstFirst ... 2345 LastLast
Results 31 to 40 of 43
Thread: Madusa Build Tread
  1. #31
    Ocracoke's Avatar
    Team Kaizen
    a. I’d need a lot of solder to keep the thin wires in place in the XT60s- is this ok?
    Probably, yes but leading onto my next statement...
    b. Just to confirm that the thin wires won’t prohibit power being routed through to the ESC and then to the motors causing us to to be even slower?
    Now what I do in The Honey Badger is have the LED effectively wired in parallel with the ESC from the battery. You are right, the thin wires wouldn't support the higher current and likely burn out, like a fuse would do.
    So currently in The Honey Badger and Shu!, the wiring for this section looks like this (oversimplified but you get the idea)...
    Osu and Ikari (my antweights) use this sort of arrangement which I am more happier with (it is a little neater - photographed whilst in development):
    BW: Shu!, The Honey Badger
  2. #32
    Hey man, I'd put a little more electric tape around the removable link wire, that little bit of exposed metal could cause a shock, haha. But it's looking good so far.
    The way I do it is that I put the LEDs after the fuses, and (and this is a big and, because I've learnt this the hard way haha) make sure there's a resistor to the LEDs, that way you don't fry them. I remember Ocracoke linking me to some LEDs that were pre-resistor'd if you don't mind paying for them. I've yet to put them on Ratatoskr yet, but from what I can see on them, they might look right up your alley.
  3. #33
    The setup I used is pretty much identical to DotDominic's Venator build. Pic is linked below, and the entire log is great if you need some help with basic wiring.
    Link to build log: http://www.fightingrobots.co.uk/thre...t-robot-please
  4. #34
    XT60 for an led wow
  5. #35
    Hahaha at the time it was the only connector I had Definitely overkill though, and you probably don't need gauge 12 wire for the LED either! I used Jamie's post in this thread as a guide for wiring - he explains the setup pretty well:
    http://www.fightingrobots.co.uk/thre...ting-power-out
    EDIT: Upon looking at Jamie's image again, it looks like I misunderstood the order of the battery and link leads, so I've had the Fuse on the wrong side for two years. Oops! The battery connector is the one on the bottom left side of Jamie's image, followed by the link top left, and then the fuse. Thanks for that, Nat!
    Last edited by dotDominic; 8th March 2018 at 12:46. Reason: Oops! Will put a little edit in my build diary!
  6. #36
    I would advise putting the fuse on the positive side of the battery lead, as this means there is no positive live on your components. very rare this would case an issue but its just common practice in electronics world.
  7. #37
    It's because a lot of the time electronics connect the ground to the case of the device, or the mounting points. So the whole frame of your bot would be battery ground in that case. It doesn't really apply here as much but for example on a powersupply you could have the ground going through the casing into the board, bypassing the fuse completely. Hence putting the fuse on the 'dangerous' wire is good because it will will always only have one return path. Making the fuse the limiting factor.
  8. #38
  9. #39
  10. #40
    Ocracoke's Avatar
    Team Kaizen
    Sounds as if there is a reverse needed on one of the channels on the transmitter possibly, I need to do that on The Honey Badger and I think it might have been for this reason.
