Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Beetleweight Brawl 2018 (unofficial thread)
  1. #11
    Albear's Avatar
    Roboteer
    Status
    Offline
    Name
    Alexander J
    Robots
    Batteries Not Included (BW)
    Location
    Wootton Bridge, IoW
    Posts
    139
    Post Thanks / Like
    turnigy 22260 3000kv 650v and hobbyking 60a sbec
  2. #12
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Michael
    Robots
    Osu - AW / Shu! - BW / The Honey Badger - FW / Kaizen (Building) - HW
    Location
    Somewhere on the Wirral
    Posts
    285
    Post Thanks / Like
    Sure it is the motor beeping? More likely to be the ESC (not clued up on this Brushless tech yet so could very well be wrong :P). The ESC manual suggests that there is no throttle signal being received (1 beep followed by a pause).
    Team Kaizen
    AW - Osu
    BW - Shu! (Build Thread)
    FW - The Honey Badger (Build Thread)
    HW - Kaizen (Build Thread)
  3. #13
    Albear's Avatar
    Roboteer
    Status
    Offline
    Name
    Alexander J
    Robots
    Location
    Wootton Bridge, IoW
    Posts
    139
    Post Thanks / Like
    you sir, are a genius. didn't know there was a manual, just found it. Lemme have a look as its not that type of beeping, its a really quick one
    its something to do with the throttle not being in the lowest position, will try to find the correct channel and mix. Problem solving people!
  4. #14
    Ocracoke's Avatar
    Team Kaizen
    Status
    Online
    Name
    Michael
    Robots
    Location
    Posts
    285
    Post Thanks / Like
    From the manual, looks to be that you need to reset the throttle position and set the pull rod to the lowest position.
    Team Kaizen
    AW - Osu
